2001 F-150 Lightning
Old 03-21-2017, 02:36 PM
StretchF66's Avatar
My 2001 Lightning check engine fault code say banks 1 & 2 Lean? I have replaced the mass air sensor and all four Oxygen sensors and the check engine light reappears after about 50-60 miles. it occasionally idols slightly ruff! any ideas? I suspect the auto choke.
Old 03-21-2017, 06:04 PM
Vacuum leak.
Old 03-21-2017, 06:07 PM
projectSHO89's Avatar
Yep, common vacuum leak.
Old 03-21-2017, 06:45 PM
StretchF66's Avatar
I have been unable to find a vacuum leak. I have tightened all the fitting between the air box and the intake. any suggestions?
Old 03-21-2017, 07:40 PM
Check the PCV system from the valve back to the intake.
Old 03-24-2017, 10:33 AM
jaymz's Avatar
Two hoses between back of engine and firewall. Very prone to rot and leaking. Go to Lightning Rodder and search.
Old 03-26-2017, 05:53 PM
turkey pan line rotted out most likely
