Axle not turning after wheel bearing hub replacement
Old 01-16-2017, 11:17 AM
Jking500's Avatar
I have a 2006 f150 4 wheel drive and am trying to replace the wheel bearing hub on the front passenger side. The bearing hub fits and is the right size, but once I tighten everything up it doesn't turn the axle as it should. You can hear the gears grinding against one another and the bearing hub itself spins, but not the axle. The old bearings were completely decimated and literally crumbled apart when I took the old hub off. Could this have damaged the axle assembly? Can anyone tell me what I'm doing wrong or do I need to replace the entire axle assembly as well?
Old 01-16-2017, 12:53 PM
I believe it takes vacuum to engage the front hubs
Old 01-16-2017, 02:58 PM
2stroked's Avatar
Pat,
Actually, it takes vacuum to disengage the IWE. That would explain the issue.
Tom
Old 01-16-2017, 09:10 PM
Jking500's Avatar
Thanks. Figured it out. The actuator was completely destroyed (probabaly locked up when it failed) and caused my wheel bearings to crumble. Replaced it and everything is working great now.
