Boat Anchor!? Hope not; '91 4.9 Wants to start but.....
So my brother's co-worker has this '91 F-150 w/ 160k on the clock.
He replaced cap, rotor, wires, plugs, module and rear fuel pump (he only always used rear tank) as well as the fuel filter. He did all this as the beast used to run great then he felt it had a starving for fuel issue/spark problem. After all this he said
** expletive deleted **, your brother likes junk: he can buy this one!
After pouring over lots of threads I started at the most expensive item, the eec. Pulled it and there were the notorious 3 leaking capacitors. Took it to a PC tech buddy and aced it up for a sixer! Reinstalled it and attempted to start, wah, wahhhh, wahhhhhh.......
It will start like a champ and within seconds die. Pump priming is audible for 2 seconds.
KOEO code is 126 MAP
So I'm going to start with checking the connections for corrosion and try cleaning them.
As I'm a cheap ****, I might just throw a new MAP non motorcraft on it, probably by BWD.
Is there anything else I should check while I'm at it?
The truck is unmolested and original, decently kept condition. No obvious hacks on wiring etc.
Thanks for your Help!!
W.
W.
It's Alive.....kinda noisy top end......
Thanks!! Worked like a Charm!
Runs pretty smooth after sitting for a year. Has a sound that seems like I've heard before on other straight sixes. Top end and similar to an exhaust leak but there isn't an exhaust leak. Maybe needs valve adjustment?
Also has "ABS Rear" light on dash......what fun!!
W.
W.
Thanks GLC! I'll give that a shot!!
Thanks again.
W.
