projector headlights
Ive been looking at some hid kits and retro fitting projectors lens for my 92 f150. Looks like the one to go with is the Mh1 kit. Just wanted to know if anyone had a link to that kit some I know I looking at the correct one also do you change the bulb like the stock headlights through the back or do i have to completely tear them apart again?
I want to do something like these:
http://hidillusionz.blogspot.com/201...-retrofit.html
Is this the right kit?
http://www.theretrofitsource.com/com...l#.U3qeJfldVbE
That is the right kit. And to change the bulb its just like changing your stock headlight bulb. You'll understand when you have the projector in your hand.
If I might make a suggestion, maybe try the Mini D2S projector its a better projector and shorter so it should fit better. Plus you can use OEM D2S bulbs. Heck even the aftermarket D2S bulbs are better than the rebased H1 bulbs.
