Key/Headlight Buzzer not working
Howdy
Just bout this 95 F150 and key/light Buzzer isn’t working. I checked the fuse and its ok. I asked all the guys at AutoZone and Pep boys about it and they dont have a clue. I called a local Ford parts dept and they said they can order the part/buzzer for $65.00, Im just not sure thats really the problem. Anyone have any experience with this or know what else I can check besides the fuse?
`B
`B
It's probably unplugged (if you bought the truck used) to start with. On XL trucks it is a very annoying constant buzzer, so many owners just unplugged it. There's a little white module tucked under the dash, closer to the driver's side from center. There's a harness connector that fits into it, so see if it's unplugged. If it is and still doesn't work, it's probably bad and would have to be replaced.
XLT's have a less annoying "chime" that dings until the lights are turned off. My truck doesn't care if the keys are left in, just if the lights are on.
Well... I found it, and plugged it in...
All I can say is...
WHAT A WASTE OF TIME!!!! LOL
The has to be the most annoying sound in the world!!!
The main reason I wanted it to work was to keep me from leaving my lights on. When I leave for work its dark and by the time to get to work there is daylight. I have killed my battery 3 times since I got this truck. But the only time it buzzes @ you is when you start the truck or leave the keys in the ignition with the door open.
Well thanks for the help, hopefully this post will stop another unsuspecting victim from connecting it or better yet guide them on how to disconnect it, just like what I am about to go do. lol
All I can say is...
