Power windows on a 92
Old 07-25-2007, 03:14 PM
mjyork's Avatar
I just bought this truck on Friday. I knew the power windows didn't work. They are both out, and I was wondering if there were any common problems. I would hate to take everything apart for an easy fix. The power locks work in the same switch, and the fuse tested good. Thanks for any help.
Mike
Old 07-25-2007, 09:04 PM
emig5m's Avatar
My 92 f150 has 176,000+ miles and ALL the electronics including the windows still work great, lol. (actually, the door speakers are toast, heh)
Old 07-27-2007, 11:52 AM
mjyork's Avatar
Still trying
I am still trying to sort this out. I got side tracked a little with cleaning, and polishing. It is actually cleaning up nicely.
Is there a relay that I can't find? The guy didn't tell me much except that the windows quit at the same time. That doesn't sound like the motors to me? I don't know. I am new to Ford's and need to get the window's working. AC doesn't, and I am not going to fix that.
Thanks,
York
Old 07-27-2007, 12:05 PM
krazyballer's Avatar
My 1990 f150 has pwr lock and windows and they work great to.
Old 07-29-2007, 08:13 AM
adrianspeeder's Avatar
Ok, do the motors run at all and the windows don't move? Or is everything dead from both switches?
Adrianspeeder
Old 07-29-2007, 03:17 PM
mjyork's Avatar
Adrianspeeder
I don't hear anything when I push the switch, but there is a power drain when I do it. I am not sure what that means, I am probably going to have to get a drill to pull the motor out.
What do you think?
Old 08-05-2007, 02:04 AM
Steve83's Avatar
Click the black Bronco in my signature & look thru the Doors album. The door window motors are identical to a Bronco tailgate motor, so look in the Tailgate Tech album, also.
Yes, you'll probably need a 3/8" drill to get to the bolt heads for the motor. There are dimples in the sheet metal indicating where to drill, and you only have to drill 2 of them because the 3rd is exposed.
But before doing that, pull the motor connector & test the wires for voltage when you work the switch. It should be full battery voltage, and it should reverse polarity when you reverse the switch direction. If that passes, put a test light across the wires & retest.
Quick Reply: Power windows on a 92
