92 F150 5.8 Engine Codes 181 334 542
I have a 1992 F150 automatic 2WD with 5.8 liter engine. It performs poorly, especially upon acceleration. Once I get to cruising speed it runs well until I come to a hill or try to accelerate. At that time the engine begins to hesitate, and under heavier loads it begins to buck. Turning off O/D and bringing the rpms up helps the problem, but it returns when I turn the O/D back on.
I just scanned for codes and got:
181 Lean during part throttle
334 EGR closed, valve voltage high
542 Fuel pump secondary fault, PCM to ground
Timing is correct, O2 sensor and TPS are new, plugs wires etc are relatively new and in good condition.
What is a fuel pump secondary fault? Would that not cause the lean condition noted by code 181? Could the MAP sensor be part of the problem?
Any help is appreciated.
