OK...got codes got stuff..still got issues... Suggestions?
OK... I'll try to be short... after dealing with the rough running unless WOT issue had codes checked.... AutoZone said EGR...hmmm... then used wrench buddy's Snap-On scanner...O2 Sensor and something about the Clutch Torque Converter ( can't remember exact wording of this one ). He recommends I do the O2 and he takes truck for tranny drain/refill with the anti-slip additive... It's probably been 80K since last refill... I say OK... $50.00 and five minutes and O2 is done... He takes truck changes fuild ( says old fluid was BLACK ) truck is much better but still has occasional "spouts" of need WOT. Tranny shifts fine...feels a little "tighter" than normal. Suggestions?? Is there a vacum modulator on these. Only other time I had problem was due to the electronic shift lever detector on driver side of tranny.... was reading things right and made truck grab a wicked second gear all the time.... One last thing seems to be worse in wet or damp weather.... Thanks !
