Instrument cluster swap - new question
I've searched through all the old topics on this subject and I have a question that I didn't find an answer to in the old threads. I am able to get a matching 95 cluster w/tach to replace my existing one, although it has a shift indicator while I have a manual shift (that shouldn't be an issue, just remove it). The cluster with the tach is supposed to be functional, but it is weather worn and dirty which makes me skeptical. The typical replacement instructions say to take your old speedo and put it in the new cluster, then install the new cluster. Is it also possible to take the tach and gauge sections from the replacement cluster and put them in my old cluster, or is there additional wiring/circuits in the cluster necessary for the change in position of the gauges?
Thanks.
Thanks.
Ohhhh, I see. I'm sorry, I thought you had taken it apart, which is why I was confused. The way the clusters are set up, the gauges snap into their electrical connectors, and since the layout is different between the one with a tach, and the one without, you can't add a gauge to one that it didn't originally have. The good news, though, is that you can find brushed aluminum plates on eBay that will cover the black area surrounding the gauges, and give it a fresh look.
