88F150 Starting Problem
Old 10-09-2015, 07:39 PM
ranfla01's Avatar
Good afternoon, I have a 1988 F150 i6 4.9l 2WD. I am not able to turn on this truck with the key, I have had to start it via solenoid. Then after a while that even stopped because the starter seemed to seize up and wouldn't turn anymore. So I replaced the starter, the fender mounted solenoid and the neutral safety switch(it's attached to the clutch pedal) but still nothing. When I turn the key everything turns on as it should but the starter does not engage. Can anyone offer any mechanical advice as to what to do next? Thanks in advance.
Quick Reply: 88F150 Starting Problem
