Am I crazy? 4X4 Problem?
Well my mechanic got a hold of it, then figured out the problem so he said and it turned out to be some kind of piston in the transfer case, then he said he had good and bad news, he said it now goes into 4 wheel drive but the front axles do not turn, so he wanted to take it back to my dealer since I still have limited power train warranty ion it for like 200 more miles and THE DEALER replaced the front axles because of bad boots.
He figures them good somehow. My dealer has not been very helpful with this 4 wheel thing since they like to quote “Limited Power train” and since the transfer case is not listed they would not cover it, well that’s when Henry my Mechanic came in and fixed that part of it, like he says I did my part, now they have to do theirs.
So what was cool is he did this Christmas Eve even and I told him just to keep her because the Dealer said they could check it out Friday, well Today is Friday and so far I have not heard anything yet. Hopefully no news is good news...
I just wonder what is bad in the Front end. IWE’s? Differential? he says the vacuum is working fine and that lever switches over on the front differential.
Stay Tuned, comments are welcome and so is speculation.
I am hoping it is the fork
[QUOTE=Bindernut;3501134]Most likely culprit. Check the vacuum operated front axle disconnect.
Sounds to me like it is either binding up on mud or rust, has a worn fork inside the front diff, or isn't getting a
Hopefully it is the Fork that is worn cause the Front Dif is covered under my warranty
I just got my 4 wheel driver repaired at a dealer, I had this fly by night mechanic try to fix it, he ended up taking it to my dealer since they at first scared me telling me it was not covered by my limited power train warranty at first, but because he could not fix it, he acted like he did and replaced some piston type part in the transfer case, wanted me to pay him $230 for doing that but it still did not work so he took it to ford to argue out with them he said that something was broken in the front axle and they should fix it..I think this guy is pulling my leg as he kept lying and lying and basically I figured he could not fix it and took it to them, they replaced a vacuum actuator in the front axle and then mentioned the front axle shield was missing, so now I am trying to figure out if the guy took it off and never gave it to them to put back on or what it is and how hard it is to get or put on?, can someone explain what’s up with the shield for me..
on
It is made of plastic. When you buy a complete front axle it usually comes with it. Call a local yard and see if they have one. Go back to your mechanic and tell him to give you back the shield, with the 3 bolts that holds it on. Have a look here; http://www.4x4posi-lok.com/PDFs/inst_750.pdf Figures 3, 8 and 9 show clear pictures of what the shield looks like. FYI I have that system on my truck.
I OWN a 1999 F-150 4x4. when I use the 4x4 - for some reason, it would stay on, it has electronic turn button with light on dash, & light was intermitent. I took to dealer /garage where I bought truck, he is also a mechanic , he could not find any problem, Said drove it 5x,
after taking to him 3x. Twice it had to be CAA towed in to city. Well I was fed up .
I took it to Ford dealership, they diagnosed the problem. The transfer shift motor is gone & needs to be replaced.
In this case it pays to go to the experts.
I forgot to ask the mechanic / MY BIG QUESTION - IS the TRANSFER SHIFT MOTOR PART OF THE POWER TRAIN ?
Thanx
Iron woman
Thanx
Iron woman
