8.8 rear end gear
Old 10-31-2008, 10:35 PM
4x497F150's Avatar
8.8 rear end gear
The 4.56s require a notch cross shaft. I was wondering what it was talkin about?
Old 11-02-2008, 06:55 AM
2002 wonderboy's Avatar
the notched cross shaft is needed on the Higher number gears, due to the ring gear extending over the hole which the cross shaft goes in. the notched cross shaft is slimmed down a little to get around the ring gear protruding.
In case you are wondering, the cross shaft holds in the spyder gears inside the carrier.
Old 11-03-2008, 12:27 AM
4x497F150's Avatar
thanks dude
Quick Reply: 8.8 rear end gear
