4x4 vs 2x4 rear quick question
He should have the 9.75, but check his axle code to make sure of his posi and gearing ratio. A few 97-03's came equipped w/ the 3.73 ls ratio. You are looking for his axle code to read H9 (3.55 limited slip), if it reads B6, he has the 3.73 ls ratio. The axle code is located on the sticker on the driver's side door jamb that contains the vin, stock tire size, etc. It is on the bottom.
