2004 f150 w/ 4.6. What rear-end?
Old 08-31-2007, 02:09 PM
MercedesTech's Avatar
Like I said I have the 2004 ford f150 (newer body style) with the smaller 4.6 liter v-8. Wondering what rear-end I have. is it the 9.75 or the 8.8? i also have the 3.73 gears with LS.
Old 08-31-2007, 03:14 PM
kingfish51's Avatar
Should be the 8.8. Look at rear diff cover. 10 bolts = 8.8, 12 bolts = 9.75.
Old 09-04-2007, 11:30 AM
thanks a lot
Old 09-04-2007, 06:06 PM
1969mach1428's Avatar
i was planning on gettin my 4.2l swapped out for a sohc mustang 4.6l. my truck's the 5-spd. manual 4x4, would i need a new back axel, driveshaft, etc., what do you think?
Old 09-04-2007, 06:35 PM
Not sure about that swap. If you are able to get some type of adapter to link the 4.6L to your current drive-train (i.e. your tranny) i don't see any need to swap rear-end or even driveshaft. I am not sure on the torque gains but I am assuming they aren't significant enough to change your whole drivetrain. Don't set my word in stone, hell i wouldn't even bet on it like I said not sure about this swap, never done it, never know someone to do it. Just thought I'd chip in with my opinion. Good luck!
Old 09-05-2007, 10:10 AM
glc is offline
Until recently, the 4.6 was available with a 5 speed manual (same gearbox as the 4.2) so that may not be a difficult swap. I would think as long as the engine is close to stock and you don't beat on it too hard the drivetrain should hold up okay.
Quick Reply: 2004 f150 w/ 4.6. What rear-end?
