How-To: Big 3 Upgrade (Extremely Pic-Heavy)
#31
Nah I haven't touched my install since about a year ago. I still have the TBI tweeters/ID mids/Adire woofers with the Cadence/US AMPS amps all in my truck. All that equipment I posted like a month ago (old school Zed amps and Seas Lotus speakers) is going in along with the SI woofers. Also will be re-routing all the wires neatly under the carpet, heavily deadening the floor, and glass molding the tweeters into the pillars. I'm gonna whip up a quick box for the BMs tomorrow or thursday, still need to decide which will be staying in the truck: the SI's or the Adires.
Dont worry I'll take plenty of progress pictures.
My week off in 2 weeks will be the first time in forever Ive had no class or work for a whole week so I'll have lots of time to get this done finally.
Yeah man...spring break. Workin 40 hours....awesome.
#32
Here's a link to Fusion connectors. Cable Terminal , -up to 1 gauge. Their not that bad on Price and they come with sized solder pellets.
Just found this site, -attempting to collect everything needed lol.
http://www.remybattery.com/Departmen...Terminals.aspx
Hey, where do you guys get your in-lines at ? This is all I have handy (40amp being max) and I'm not having much luck locally.
Most likley online somewhere or a stereo shop, Radio Shack? I've been using an old amp for many years without problems, so far. It's a 400 watt Kenwood 4 channel into 12" Technics woofers w/a SuperTuner driving it all. KW 6x9's in the doors as well. - Told you it was old lol, - but still sounds amazing IMO.
#33
#34
http://www.darvex.com/battery_terminal.html
NICE!
Thanks for the links Sal
#36
You guys use some heavy stuff. I guess all I need is a link to match wire gauge right ? So I think 40 is sufficiant since I'm not adding more power and most likley , I'm not pushing half of what you are or will be...-Yet! My amp runs with a 35 in the back. I believe it's 10 or 12 gauge running to the battery.
Am I good or should I go heavier their as well ? Will it make a difference ?
#37
Do you have specs on what your running? I run minimum 8 gauge wire to low-power amps. The only thing I use 10 gauge power for is remote starts where the car has low amperage 12volt at the ignition harness and for power inverters. As for the fuse holders, i have simple glass fuses rated as low as 30 or 40 amps. Its not like you have to stick a 120 amp maxi fuse in there.
#38
Thanks, but mann, I think I'm getting a little to crazy with it. I've never blown that little 40 amp fuse. I do hate that pink color tho, - yea yea, I'm a little prejudice I expect, -It looks fairy.
I use 10awg for speaker cable powering my subwoofers and 12awg for the mids and tweeters.
#39
With a 40 amp fused amplifier 8awg should be the minimum you use, especially if your run from the battery is longer than 5 feet or so. The longer the run of wire from the battery, the less power the cable can handle safely for extended periods.
Ah Crap, I'll go see what it is real quick, -it's 8 or 10.
Well, I looked at it, what's funny is, it looks larger than the 40 amp fuse wire ? I can strip the insulation with 10 awgs so I guess it is 10. Iduno, I'm goin to bed lol.
#40
Yea, it's 10. So now I guess I have to gut the cab for that wire and run a better in-line for it. Oh well, I want it done right! Thought I had the wire sized accordingly, it's not looking that way. Also, the in-line fuse wires have oxidation on one side and a little corrosion on the other, -soo.. Bartak, who use to frequent this site, not sure if he still comes around; -you guys most likley don't know him, but he gave me a hand on the install and amp settings, wiring -got it sounding killer. That was 3 or 4 years ago. I do have pictures of the install, but I probably shouldn't post them in mblouir's nice right up. I'll start a thread somewhere in audio or electrical once I get it all apart.
Thanks for all the info fellas, -Sundevil I'll PM you for more info on those in-lines before I order a new one. thumbsup:
Well, I can't find my wire gauge. 4 sets of insulation strippers. One set the wire will thread thru the 10 AWG slot, the others it doesn't, so now it may be 8 ? I'm going to pic up a new wire gauge tomorrow. Geezzz Wiring isn't marked and I have nothing to gauge larger than 10 at the moment...No laughing!
#41
Heavy Wall Adhesive Lined Heat Shrink Tubing
3:1 Shrink Ratio with melt adhesive inner lining (shrinks to 1/3 its original diameter.)
http://www.buyheatshrink.com/heatshr...polyolefin.htm
#43
#44
#45
