Last edit by: IB Advertising
Heater core replacement! Step by step with pictures
http://www.f150online.com/forums/hva...-pictures.html
ISSUE
Step-by-step instructions for Do-It-Yourselfers for how to replace heater core
Read below for the full discussion…
ISSUE
#34
#35
help no air now
Ok so I finished replacing the heater core, blend door and blend door actuator this last Sat. in my 2001 F150 extra cab. However now when I turn on the heat or air no air comes out. When I turn the climate control **** I can hear the blend door moving but I get no air when I turn up the hot and cold **** or the speed control ****. Any ideas what would cause this to happen? I had air flow before just no heat. I checked all the fuses in the drivers side fuse box and all were working. I'm thinking I must of missed connecting a wire that controls the air controls. I thought it may have been bad control board so I replaced that and still nothing Any ideas what I need to check?
Thanks,
Heath
Thanks,
Heath
#36
I clicked on the document and couldn't pull it up? Can you email it to jasonkingsolver@gmail.com
#37
Emailing it won't help - you need software that can open a Microsoft Word document. It downloads and opens fine for me when I click the link.
Free Microsoft Word Viewer:
http://www.microsoft.com/en-us/downl...ails.aspx?id=4
(Note - you need a computer with Windows on it, not just a phone)
I would also HIGHLY recommend you edit your post and remove your email address - posting it in an open forum is inviting a ton of spam.
#39
http://nator.net,dont work,everytime I click on that link it direct me to yahoo with messageage not found...
#40
#41
I rehosted this on Google Docs so it's viewable without Microsoft Word and not dependent upon anyone's hosting disappearing. Unless you're worried about Google disappearing, that is.
https://docs.google.com/document/d/1...it?usp=sharing
#42
Hey yall... can on so i followed the job step by step... with 1 exception for loosing the ground wire that i was told specificly not to forget... located on the lower coloumn panel next to the E Brake release... well its gone into hiding lets say... Anyway does anyone know were that ground wire is located? Or maby a destination i can back track it from? ive got the dash opened all the way up again and still cant locate
Kalifornia Kustoms
Kalifornia Kustoms
#44
#45
Hello all, thanks to everyone that helped me out with a previous post on "How to replace your heater core" This might come in handy this winter . This post has not only "black and white" pictures, but actual digital pictures as well. This was a great help, made things very simple! Enjoy
http://nator.net/files/Heater Core Replacement.doc
