Any spark plug guru's?
Old 11-18-2016, 12:55 PM
ruffn-it's Avatar
Any spark plug guru's? (non-ford, boat)
So I accidentally put ac delco 41-110's in my boat with the mercury 5.0 mpi engine. I got the part# mixed up with the correct one 41-101 (41-993 is also an alternative). I haven't started the engine, don't plan on it and I've already ordered the correct plugs but I've been searching online for the specs for the two plugs to see if the 110 will work. Obviously if I can't determine that I'll swap them out, just thought I would throw this out before I swap them to see if anyone knows. I tried contacting ac delco customer support and they said contact a dealer...not much help. The best I could find on specs were attached to order placement with other companies...
Part Number:41-101Weight:0.1 lbsHex Size:5/8 in.Thread Size:14 mm.Electrode Core:CopperResistor:4-7.5 k?Heat Range:4Electrode Tip:IridiumInsulator Type:High Alumina ceramicRib Configuration:RiblessThread Reach:0.750 in. (19.00 mm.)Terminal top fixed or threaded:FixedSeat Type:TaperedShell Type:Zinc
Part number:41-110 http://m.oreillyauto.com/h5/r/www.or...3435&ppt=C0334
Old 11-18-2016, 06:03 PM
glc is offline
Heat range is way off, I wouldn't run it.
Old 11-20-2016, 12:42 AM
ruffn-it's Avatar
Change them it is, thanks
