No power at all
Old 05-27-2015, 09:08 PM
F150powr's Avatar
No power at all
Ok so I have an 03 f150 XLT with the 5.4 liter 2v engine and I recently had a blown passenger head gasket so I took the engine all apart had the heads machined put everything back together (atleast I think I did) and now with the battery hooked up and holding 12.5 V nothing has any power at all, no lights nothing but I can hear the relays clicking on and off constantly. I think it's that I didn't hook up a ground wire, so any ideas at all would be great!!
Old 05-28-2015, 07:09 AM
RevBiker's Avatar
Check grounds to the engine! This is dumb but you hooked up the battery correctly right, seen guys not thinking put cables battery backwards?? My guest is grounds not hooked up.
look around the backside of the engine passenger side. Also do a load test on the battery, Advanced or Autozone will do this for free or recharge it. After a recharge could have 12v but no amps= bad battery
Old 05-28-2015, 08:16 PM
F150powr's Avatar
The battery worked fine before, and it only sat for 2 weeks, and the battery cables were hooked up right, and I'll have it tested and charges at autozone soon
Old 05-28-2015, 08:17 PM
F150powr's Avatar
And I'll check my grounds
Quick Reply: No power at all
