Ford 500 Disable Key/Door chime-HELP!
This chime is driving me crazy! It is extremely loud - scares the crap out of me and wakes up the kids. Chimes with every door/trunk opening, keys in the ignition, 10, 5, 4, 3, 2, and 1% oil life, turn signal on off ramps, etc... I have driven other fords and the sound is a pleasant 'ping' - mine is more like an alarm - literally makes you jump out of your skin when it comes on.
After taking apart the dash I found the little box causing all the trouble but it is located inside the circuit board box containing the spedometer and other guages. I cannot access it without breaking the box. The dealers will not program it to stop. I cannot access it even to cover it a bit to make it quieter. Can someone PLEASE tell me which wire to snip off of the harness to make it stop??? Or tell me which fuse controls it??? The owners manual is no help with this.
I doubt that there is a fuse and also doubt there is a wire to snip when it is built into the instrument cluster. Be sure and tell us what vehicle your working on.
My car is a Ford 500 2005. The black box is small - can't see the entire thing - located in the small space between the spedometer/tachometer and the circuit board behind them. I cannot get in there with a tool to get it out without damaging the glue and clips that hold the entire unit together. I was hoping there would be a wire just for that. I am afraid of damaging the circuit board or panel if I open the case up. Any tricks to it? Thank you so much for the response you gave!!
