Horn Problem with 97 F-150 XLT
Old 06-06-2006, 06:44 AM
brandonacoleman's Avatar
Hi,
I have had my F-150 for about 6 months now, and about 2 months ago, when I came home from work, I used the keyless entry to lock my doors. When the horn chirped, it laid on the horn. The only way I could stop the horn was to disconnect them from the cable. I couldn't disconnect them from the fuse box. I tried both the relay and the fuse.
Has anyone had this problem? Or have any advice?
Brandon A. Coleman
Old 06-06-2006, 08:44 AM
projectSHO89's Avatar
Fuse F5 or horn relay removal should have removed power from the horns if you have a factory alarm.
If it's an aftermarket alarm, it was probably installed so it directly operates the horn. In that case, the aftermarket alarm is the problem.
Steve
Old 06-06-2006, 06:16 PM
Steve,
Worked nicely, thanks.
Since my horn did stick, do you think I would have to replace the entire horn system, including cruise control?
Brandon A. Coleman
Old 06-06-2006, 08:13 PM
Uh, what worked?
You really haven't done any diagnosis yet, have you?
Steve
Quick Reply: Horn Problem with 97 F-150 XLT
