Intermittent Odometer - A Repair
Old 12-22-2014, 05:03 AM
olabyse's Avatar
i changed the brainbox the car starts with any key and thats very dagerous because of theft
  #242
Old 04-19-2016, 11:45 PM
I did it and it worked for a few weeks to a month now it's not working at all.
  #243
Old 04-19-2016, 11:47 PM
I read they are related to pats so I guess I can't get a used one as a plug in play. Does a 2001 have to be flashed or programmed if I get one from another truck? What years are compatible ?
  #244
Old 04-19-2016, 11:51 PM
2001 should be PATS. Easily identified by having a large plastic base on your key.
I believe any PATS cluster is compatible with programming. 99-03 IIRC
  #245
Old 04-20-2016, 12:06 AM
So I would have to take cluster to a dealer?
  #246
Old 04-23-2016, 09:52 PM
hit train tracks and odometer came on briefly for the 1st time in months.
  #247
Old 03-31-2017, 11:09 PM
councillor's Avatar
I guess I have to do this also, I have 2000 lightning and the read out display goes in and out for no apparent reason.
  #248
Old 05-06-2017, 02:42 PM
phildirt's Avatar
I am attempting this on my 2004 F150. What's the trick to getting the gear shift position cable unhooked?
  #249
Old 07-01-2017, 11:09 PM
Andrew Ross's Avatar
Fixed mine today
this has been an issue since my girlfriend acquired this truck from her father. Been driving me nuts. I was pretty quick at pulling the dash apart but then realized my soldering iron had gone missing.
I went to Harbor Freight and picked up a new one and had the job done in just over an hour.
Hope it lasts and does the trick. Thanks to the original post to walk me through the process!
  #250
Old 06-05-2018, 08:56 AM
Jeff Flewelling's Avatar
Tried this it didn't work also now speedometer not working any ideas
  #251
Old 07-10-2018, 03:24 PM
serta1's Avatar
2001 F150 Odometer intermittent issue
Hello, I know that this is an old post but the information was great. I have a 2001 F150 with the intermittent odometer issue. Took the speedometer out. The only thing is that I did not have to remove the headlight switch. Once I pulled the dash cover I could reach around and unplug it from behind. I took the circuit board to the shop that I use to repair my vintage stereo equipment. He put his magnifying goggles on and agreed that the solders had issues. Took him 30 seconds to redo all 9 solders for no charge. I did try to protect the plastic cover on the steering column when reinstalling but still did scratch it a little. It has been a month now and still working great. Thanks for such a great post.
After the re-solder of the 9 defective ones.
Now working.
  #252
Old 10-17-2018, 08:42 AM
Fbird's Avatar
My turn i guess.... will post anything different as needed 2002 f150 4x4 lariat...
Quick Reply: Intermittent Odometer - A Repair
