No tire spin from dead stop
Old 11-20-2015, 07:02 PM
stuck screw's Avatar
Do some research on the topic of torque management and I think you'll find your answer.
Old 11-20-2015, 11:19 PM
dranger962000's Avatar
my truck only spins when I power brake...
Old 11-25-2015, 03:34 PM
Blown F-150's Avatar
You can hit your traction control button once to "disable" traction control, which really doesn't do much. If you hold the button for 10 seconds, it should disable advancetrac and then you should notice a difference.
Old 11-29-2015, 11:55 AM
MKTRUCK's Avatar
Originally Posted by tbraquet
If I had a Mustang I'd be doing what you say I shouldn't be doing and breaking the law. LOL
BTW, I never said I was doing this on the street. I have access to plenty of private property I can play on.
Traction is the key to victory. My 3.31's spin the tire...And it's a 5.0. I'm also not ready to buy new tires, so it only happened once or twice.
Old 12-18-2015, 09:22 PM
hmustang's Avatar
The way I look at it if your spinning the other guy is winning. My 05 5.4 with 196k+ on it can still spin the tires when I stomp on it.
Old 01-23-2016, 10:25 AM
Mpkav's Avatar
If you double tap the traction control button it turns into "advance trac sport mode!!" Have fun!!
Old 01-24-2016, 05:57 AM
99and04f150's Avatar
Lit mine up the other day while making a right..... Dead stop, wimpy 5.0 and 3.31 gears.....
Prolly won't do it again. Tires are spendy.
Old 04-21-2016, 07:27 PM
zotman21's Avatar
I do that for fun and spin tires at any time. 5.0 with 3.31
Old 04-24-2016, 04:58 AM
Mike Up's Avatar
Maybe something with the 2015s. My new 2016 wants to bark the tires all the time. In fact, when giving it throttle to pass someone, I accidentally gave it to much (still learning that this thing has incredible power), and barked the tires at 35 mph when it downshifted.
The Ecoboost 3.5L I test drove didn't spin the tires as easily and it still had the 3.55 locker while mine does have the 3.73 locker.
With the weight to power ratio, even with 3.31 gears, spinning the tires shouldn't be a problem. I haven't seen to much torque management yet, but I haven't got into the throttle at stops. Hek, it barks the tires when I'm trying to take it slow. Much more power off the line and up in the rpms, than my previous 2012 F150 that was configured the same as the 2016.
Quick Reply: No tire spin from dead stop
