2016 F150 single cab FX4
Old 04-06-2016, 08:40 PM
joe t.'s Avatar
Wonder what the tailgate emblem looks like.
I might get all ricer and change mine out.
Old 04-06-2016, 09:31 PM
glc is offline
Old 04-06-2016, 09:47 PM
crazynip's Avatar
Now you just need some fuzzy dice!
Old 04-06-2016, 11:27 PM
joe t.'s Avatar
If you haven't seen the 09-14 Mexican Lincoln LT it definately needed some fuzzy dice. That was an ugly dog. It was an f150 platinum with a body kit or some ****.
Old 04-09-2016, 11:06 AM
billymac79's Avatar
tires
Originally Posted by carlosc04
Yes it's a 5.0L. Yes it comes with the pro-trailer back up assist. I ordered it pretty much with all the bells and whistles you can add to a single cab.
Carlos I just bought a 16 shortbed fx4 and it came with 245/70-17 and want to go to 275s on the stock rims. Did you have to put a leveling kit or lift? Thanks.
Old 04-10-2016, 12:14 PM
wolverine08's Avatar
Would be nice to be able to order with a sliding rear window but don't see it as on option on the regular cab which is a negative. C'mon Ford, l use mine for longer pieces of pipe or trim on trips from the lumber center.
Old 04-22-2016, 12:21 AM
BeyondLimitz's Avatar
I am in the market for a regular cab ford or gmc. Will be taking a look at them this sunday.
Just some quick questions regarding the ford.
Is the regular cab available with the larger screen? I see the op has it but i dont see that option when building one online.
Are the led strips available on the xlt?
I really want a black xlt regular cab 2wd with the 5.0 and 3.55 gears if the 3.73s are not available. How are you guys liking your trucks?
Old 04-22-2016, 06:31 AM
05RedFX4's Avatar
Originally Posted by BeyondLimitz
I see the op has it but i don't see that option when building one online.
You have to get the nav option or Sync 3 then it will upgrade you to the 8" screen. That's the only way to get the big screen.
Old 04-22-2016, 02:52 PM
crazynip's Avatar
You should be able to get the 3.73 with 4x4 and the 5.0, but not 2 wheel drive unless you get the Heavy Duty Payload Package.
Old 01-26-2017, 03:07 PM
5.lobo's Avatar
Clean truck whats the info on tires, dose it have a leveling kit also any rubbing
Thanks.
Old 01-27-2017, 01:11 PM
Paul888's Avatar
Mexican cars and trucks are not rated on looks but how many illegals they can carry over the border.
Old 05-28-2021, 07:16 PM
singlecab5.0's Avatar
Here is my 2016 F150 5.0 singa
Quick Reply: 2016 F150 single cab FX4
