Sponsored by: DashLynx
2012 F150 front end wobble / popping
Old 11-28-2015, 07:46 PM
ML504's Avatar
I noticed that the truck when in reverse and the wheel turned all the way to the left, there is a bobble feeling in the passenger front wheel area and slight popping noise. I haven't noticed it in other situations other than as described. Anyone have any ideas?
Thanks,
Matt
Old 11-28-2015, 08:15 PM
glc is offline
Is it in 4wd? If so, normal, you shouldn't do that.
Old 11-28-2015, 08:21 PM
ML504's Avatar
It's 2wd.
Old 11-29-2015, 09:46 AM
Sounds it might be the upper ball joint going south. Ball joints make that popping sound when cutting the wheel.
I'd have it checked out.
Old 11-29-2015, 12:49 PM
ML504's Avatar
Thanks.....is that normal for only 26,000 miles on the truck?
Old 11-29-2015, 12:58 PM
Not normally. But I had a leaking strut on my truck at 30k. So anything is possible. It might just be defective.
Old 11-30-2015, 09:46 AM
FordService's Avatar
Ford Customer Service Team
Thanks,
Matt
Hi Matt,
It sounds like it's time for a trip to the dealership to have this noise checked out. Since you can replicate it pretty easily, take your tech on a test drive and demonstrate it for them. Come back and tell us how things go; I'll be here if you need my help.
Crystal
Quick Reply: 2012 F150 front end wobble / popping
