Replacement key help!
#46
Here's a simple explanation I found on line of how the system works. True value keys must just copy the already programmed keys frequency.
"When you attempt to start the vehicle, the onboard computer sends out a RF signal that is picked up by the transponder in the key. The transponder then returns a unique RF signal to the vehicle's computer, giving it the ok for the vehicle to start and continue to run. This all happens in less than a second, and is completely transparent to the vehicle operator. It is a very effective system that does its job without the vehicle owner having to think about it, or modify his / her usual routine."
#47
The truck does have a BOA remote start. Doesnt work right now, but plan on havinh a buddy look at it when i get time. I believe it mite have sum kind of bypass module hooked into to allow remote start to work instead of having a key stored in a box under dash. Dont think the bypass module would b preventing me from programming key but not positive.
#48
#49
If it has a remote start system, they may very well have used one of the original, or a cut third key as a donor key. I'd be looking for a box inside the steering column covers. They may very well have cut the key portion off, and just used the chipped portion. If that is true, then you could easily have your hardward store clone the "hidden key".
Just a thought worth looking into.
#50
I will be looking into it when I get a chance. I did see a box mounted under there that said bypass module. I know when I had my 2001 f150 and got he remote start, I had to pay an extra $50 for a bypass module box because of the chipped key. Hopefully I will get it all figured out eventually.
#52
