Engine won't start always
Old 01-28-2017, 01:15 AM
ford F150's Avatar
Had this truck few years no engine codes...motor size 4.2l....it always start with in a1/2 second to one of ever goes that far...I don't drive it every day...has about 160k miles...in the last few weeks it's been raining in s .ca so one day I got on the truck the engine cranked...few second it won't run or try to run....released the ignition key tried again to crack engine for anther 2 to 3 seconds engine won't start...The 3 rd time it started from the 1 second...runs prefect....so I thought maybe too much humidity...in motor...possible why...in a week it did that again...and some days start ad usual immediately...few days ago it took a minute won't start....or try...waited a minute and cranked it started prefect...and as of today it is prefect....what part...sensor shall I need to test...any idea...I hear the fuel pump...is it possible the pump...if so...why it does not stall when I'm driving it...brain storm if possible please.
Old 01-28-2017, 02:24 AM
Dbrainard's Avatar
Had similar problem in my 97 4.2 turned out to be the stupid starter safety switch ford hooked up to the brake.
Old 02-04-2017, 12:41 AM
ford F150's Avatar
thank you for the reply...I'll look into that...again thanks
Old 02-05-2017, 12:44 AM
jethat's Avatar
If you have noy replaced your fuel filter you should do that.
Old 02-05-2017, 10:29 AM
Roadie's Avatar
Check the fuel pressure. It's easy on these trucks.
Old 02-09-2017, 11:50 PM
ford F150's Avatar
Thank you guys all for reply...I replaced fuel filter...it's ok....don't know if that resolved the issue or was the issue...next thing maybe replace file pump
