Help. No tail, brake or blinker lights in rear
Single lady with F150 supercab. 2002.
My blinkers in front work except very rapid blink, my headlig
Lookat ithts work, but only if I turn them on headlights rather than automatically when truck starts. My blinkers work on side mirrors and my front parking lights work. I just have nothing working in rear. I have checked fuses there all fine. If abusive this until I get it fixed. I already paid a guy 100.00 to look at it. He said wiring all needs replaced wants another 200. To tear working out n replace. But if I have lights in front than Its not all the wiring. Can someone please tell me what else I can check
Thank you.
Thank you.
Common sense says it is the harness going to the rear is open at some point from a cut or disconnect, if all the lights are out..
Unless you look at it yourself or have trust in who does, there is not other solution.
When did this happen?
What has likely happened to cause this issue?
Good luck.
Good luck.
