Disconnected airbag
Old 10-12-2015, 09:12 PM
Shane Dulemba's Avatar
Disconnected airbag
Hey guys I've 1990 F1 50 V8 4.6 L I recently discovered after receiving this my friend but the scary is not aligned properly I disconnected the airbag because of my parents fear that it would go off sideways and be dangerous is there any truth to this is it possible that it could be dangerous going off sideways
Old 10-12-2015, 10:11 PM
jethat's Avatar
in 1990 they didnt make a f150 with a 4.6 The airbag is designed to go off facing out. I dont see haw it could be a hazard from misalignment. unless you somehow managed to mount it facing sideways.
Old 10-13-2015, 12:26 AM
glc is offline
Cough up the 60 bucks and go get an alignment!
Old 10-13-2015, 08:32 AM
2008_XL's Avatar
Your posts are a tough read. Please re read them and correct them before posting and others will have an easier time assisting you.
Old 10-13-2015, 09:14 AM
Rotational direction has no significant change. You think the engineers assume your wheels are always pointed straight forward when you get impacted?
Old 10-13-2015, 01:38 PM
Bluegrass's Avatar
Shane, you have 7 threads out of 25 displayed on my monitor.
See what you can do to combine your questions to reduce the number of threads.
Review your writing and make word and sentence completion corrections before submitting.
To help, enable spell check on your computer.
That will underline misspelled words. Right click on the word and a drop box will appear with the possible words you trying to spell. You recognize the correct word then click on it and it replaces the word, but can mistake the 'correct word' at times, so pay attention to that.
Then use the preview button and take a second read before you submit a reply.
Shane, it's very telling what you do and don't do.
There are two air bags, one in the steering wheel and one behind the large oval in the dash above the Glove box door.
They fire directly to the rear unless deflected by what is in the seat.
It is usually illegal to disconnect the bags especially for Insurance claims after an accident should they not deploy and cause driver/passenger injury that might have been prevented or reduced.
Same with seat belts.
Both normally cause an audio and visual alarm when not in service.
Normally your state inspection demands these items are in working condition.
Get your vehicle up to safe operating standards and these items won't be an issue at anytime, inspection or not.
Good luck.
Quick Reply: Disconnected airbag
