electrical problems
Old 09-17-2015, 02:40 PM
rbthgrt's Avatar
electrical problems
98 f150 keeps blowing the fuse for the cruise control,back up lights and heater-ac controls. all are on the same 15 amp fuse. I replaced the ac compressor and clutch but still the same problem. anyone else have this problem and how did you fix it
Old 09-17-2015, 03:16 PM
projectSHO89's Avatar
Which fuse (see owner's manual)?
Why did you replace the compressor and clutch?
Old 09-17-2015, 09:22 PM
kd4gij's Avatar
I just fixed that problem. Most likely problem is a short in the harness. Follow the harness from the tranny back. Look for a place that it is touching the exhaust. Mine was laying on the EGR tube on the passenger side near the fire wall. This is a common problem. That fuse goes to the relay for the ac clutch. So a bad clutch or compressor wouldn't blow that fuse. Good luck And let us know how you make out.
Quick Reply: electrical problems
