Front end leaking grease?
on
1 Post
If it is a 4x4 then check your CV joint boots on the axles. If they are ripped, cracked or torn they will need to be replaced. You would probably be better off to replace the whole CV axle assembly if that is the case as the joint will be contaminated with dirt etc. and not long for this world anyway.
