Rear leaf spring squeak?
Hey guys I have a terrible squeak coming from my rear springs. The sound is deff. Coming from the spring eyes and or bushings. Is there any way to eliminate the sqeak without removing the springs, and if removal is neccasary how should I go about fixing the problem? Also if I remove the springs can I reuse my u bolts for the rear end or replace them?I've heard replacement is not neccesary but I've also heard that it's not safe to reuse them? Any advice is appreciated and btw I tried wd40 and pb blaster bt that just doesn't work the only time the squek quits is when the springs get wet in rain or after washing the truck, just thought I'd throw throw that out there.... Thank you in advance, muddy
take a floor jack and jack your truck up from the trailer hitch, then loosen the bolts on the ends of the springs and put marine grease in them, then soak the rest in pb blaster, it will take a little while to work in but i finally have eliminated the squeeking, now i just need brakes haha
