Fuel tank pressure sensor
I broke my fuel tank pressure sensor for my 2001 f-150 5.4 xlt ext cab. The numbers off the sensor are
f88e
9c052
aa
oj2808
what other vehicals use this same sensor. The ford dealer wants $175.00 for this part but i see some online for around $70.00. For instance there is one for a 2001 excursion 5.4l. Does anyone know what other model vehicals i could use to replace this part?
Thanks much.
f88e
9c052
aa
oj2808
Thanks much.
on
Assuming you do not have a natural gas vehicle, the Ford part # is XS4Z9C052AA with a dealer list price of $111. The NGV version lists for $175.
Rockauto sells the Airtex/Wells Part # 5S6080 (SU7379) replacement for XS4Z9C052AA for under $50. Standard Motor Products also makes and sells a replacement.
You can also call your local junkyard and they should be able to look it up on their parts interchange system to see what other vehicles used the same sensor. The Wells interchange guide shows their replacement sensor fits a very wide selection of Fords from 97-10.
