Where to buy Wheels and Tires(new) for Drag Racing
Old 09-07-2002, 03:36 AM
SILVERLIGHTNING's Avatar
Question Where to buy Wheels and Tires(new) for Drag Racing
I'm looking to get a NEW set of wheels and tires just for drag racing. Where should I look?
Old 09-07-2002, 05:06 AM
LARM1's Avatar
How fast are you looking to go? Do you want a drag radial tire or a full slick? Or an E.T. Street? If you're looking for a slick tire, then you want to look into a set of Mickey Thompsons or Hoosiers. Drag Radials is a whole different ball game. If you're running a slick, I'd just get a cheap set of tires...something ugly like a mustang turbine or 10 hole wheel, because you won't be driving too long on the streets with a slick tire on the back, especially when it rains. You need to look into these things, and decide which is better for you. Most of the guys I hang out with (mostly fox body mustangs) are running e.t. streets on an extra set of welds. Welds look awesome on a lightning, but like I said, if you're gonna be riding around, you're gonna look goofy with 2 different sets of wheels, and welds aren't too cheap.
Hoosier also makes a pretty awesome drag radial...they're called quicktime pros.
http://www.rsracing.com/rscatalog/as.../rt-qtdrag.asp
Here's a full slick:
http://www.rsracing.com/rscatalog/as...rt-drslick.asp
And here's a drag radial:
http://www.rsracing.com/rscatalog/as...-proradial.asp
I recommend Hoosier or Mickey Thompson for drag racing. Nitto also makes very nice drag radials. http://www.nittotire.com
If you're looking to keep the car 'streetable' go with a drag radial, if you're using these tires to strictly race, and then bolt on a set of street tires afterwards, go with a slick or a quicktime pro. Hope that helps.
Old 09-08-2002, 12:09 AM
Thumbs up Thanks Larm
I think I'm heading toward MT ET Street 26-11.50x16(3.55gears)
16x10 rims are hard to find in a 135-5 pattern.
Thanks again for all the help.
Old 09-08-2002, 05:15 AM
LARM1's Avatar
Thumbs up
Not a problem. I'm heavily into drag racing. Let me know how they work out for you. Also, before you run them, make sure you do your research on tire pressure with a slick tire. Usually on a mustang, most guys run about 12-16psi in the tires with a slick tire. It helps the tire hook up a lot better then running with more pressure. Be sure to let me know what times you net. Good luck.
Old 09-08-2002, 07:47 AM
Thumbs up OK - Will Do !
Philly huh?
Where do you race?
Old 09-10-2002, 12:38 AM
LARM1's Avatar
Around Levittown. I run a racing website. Check it out sometime. http://www.ltownracing.org
Quick Reply: Where to buy Wheels and Tires(new) for Drag Racing
