Re-Using stock Lug Nuts on AR Baja's ?
Old Oct 20, 2001 | 08:15 PM
helper's Avatar
I was planning on using stock lug nuts with my new AR baja's. Any problems in doing so ? Or do i have to pay an arm and a leg for conical seat / tapered lug nuts ???
Thanks a Bunch !
Old Oct 20, 2001 | 08:17 PM
helper's Avatar
I forgot to mention...
Ooops, forgot to mention i have a 2001 F-150 with the post-recall lugs / nuts.
Old Oct 20, 2001 | 10:31 PM
powerstroke73's Avatar
If the reccommended lug nuts are tapered I don't think you can use your stock ones. If they are tapered that should mean that the wheel is lug-centric (wheel is centered by the lug nuts) and not hub centric (centered but the hub). New lug nuts shouldn't be too expensive, but I think you have to get them.
