275/55-20 vs 305/50-20?
Old 05-17-2018, 06:27 PM
tbear853's Avatar
Gonna be ordering tires later this year, they'll be used on my just slightly lowered '07 FX4 F-side on factory 20" wheels.
I have looked at several sights, 275/55-20 (oem) is about same diameter as 305/50-20,
I would even consider putting 305s on rear, 275s on front. The overall diameters are closer than a new tire vs old tire so it should work.
Thoughts?
Old 05-17-2018, 07:03 PM
Your tires need to match all four corners on a 4x4 or AWD. If not, you'll bust up your driveline.
If it's 4x2, then it doesn't matter if you run staggered tires.
Depending on the truck, a staggered tire setup is neat.
Last edited by ManualF150; 05-17-2018 at 07:05 PM. Reason: I can't spell staggered... LOL
Old 05-18-2018, 10:33 AM
jimbo74's Avatar
since it is an fx4, doesn't that mean it is a 4x4?
Old 05-18-2018, 05:27 PM
tbear853's Avatar
Yep, it's a 4x4 .... but the tires I'm considering are virtually same OD ... as close as if I just mixed new with well worn .... and if / when I use 4x4, it's slick out or I am in the yard.
Quick Reply: 275/55-20 vs 305/50-20?
