2005 f150 shake between 50-60 mph
Old 03-21-2018, 01:57 PM
clarkdr's Avatar
Can you tell me why my 2005 f150 steering shakes between 50-60 mph? I thought it was the tires so I bought new Michelin tires a few months ago. It's still shaking.
Old 03-21-2018, 05:01 PM
glc is offline
Get the tire store to check it out. It could be a tire issue, wheel issue, or suspension issue.
Start with the tires - make sure they are not out of round, have them road force balanced. Check for bent wheels and loose steering components.
Old 03-21-2018, 06:29 PM
Roadie's Avatar
Probably not the tires if it was shaking before and after new Michleins but you never know. A weight could have fallen off or an idiot could have done the balancing. I met one of those.
Old 03-21-2018, 06:41 PM
Make sure there isn't crud on the wheel mating surfaces to the rotor and hub.
If there is, use a wire wheel on a power drill and scrub it off.
Quick Reply: 2005 f150 shake between 50-60 mph
