Rotors - wheel bearings
Old 03-17-2018, 04:54 PM
Onmyown's Avatar
I am replacing the front rotors on my 2005 Ford F150 XLT 5.4 RWD. Do I have to replace the wheel bearings as well?
Can anybody help please.
Thanks.
Old 03-17-2018, 05:08 PM
Yes, you need to. They are part of the rotor.
OR you can get the Centric 2 piece kit... then you can (in the future) use the 4x4 rotors (the ones that don't have the integrated bearing built in).
I got the Centric kit... only because I wanted it. Plus I have another set of hubs with fresh bearings if the set in those go. I just keep a rotation.
Whatever you do... DO NOT RE-USE the spindle nut... you know, that one that is stamped "DO NOT RE-USE" on it... also make sure it's exactly torqued down to 295 FT/LBS.
Old 08-13-2018, 12:45 AM
Fifty150's Avatar
Any feedback on the Centric 120.65128 kit? How well did they hold up? Are you satisfied? Were there any problems? Would you buy them again?
Old 08-13-2018, 09:31 AM
Yes, I am still satisfied with my Centric kit.
Old 08-16-2018, 01:52 AM
Fifty150's Avatar
I'm on the fence. Looking on amazon, the reviews have been mixed. But I also have to consider that a lot of people do reuse the spindle nut, do not accurately torque down a new spindle nut, and factor in that some of the Centric kits were shipped with parts not in exact tolerance range. On the one hand, it would allow for a wider range of rotor selection. On the other hand, my truck is on a lift kit, with bigger tires, and the kit is probably designed for OEM specs.
I have been using PowerStop, and I am satisfied with the brake kit. Problem is that they are expensive.
Old 08-16-2018, 07:52 PM
I would just continue if you are happy.
Quick Reply: Rotors - wheel bearings
