Ceramic Front Pads
Old 08-16-2017, 10:40 AM
BlueOvalFitter's Avatar
Question Ceramic Front Pads
2007 F150 XL, 4.2 V6, 139K Miles
Hello all. I usually buy WAGNER THERMO-QUIET pads. The current pads on the front have 40K miles on them. I just recently had some raised white letter tires put on my truck. The WTQ's are supposed to be low dust, but ARE NOT. My white letters are black!
Q? What is a good ceramic pad, priced low, that has less dust then what I currently have on my truck? RockAuto has POWER STOP ceramic pads for $26. They also have AKEBONO ceramic pads for $56. Keeping in mind I'm on a budget, which would be better, last longer, and low dust? Or, are they about the same?
Old 08-16-2017, 04:01 PM
Dog'em's Avatar
I put Akebono ceramics all the way around about six months after I bought my new 05 and they are still holding up very well with absolutely no dust.
Old 08-16-2017, 05:37 PM
glc is offline
CENTRIC 10510110 Posi-Quiet Ceramic w/Shims and Hardware Front
$32.79
http://www.rockauto.com/en/catalog/f...brake+pad,1684
I had a set of those on the front of my 2003 and they lasted 115k miles with *NO* dust. Recommend you have the rotors turned on the truck. Rotor replacement is expensive because they are integral with the hub, and the spindle nut requires 295 ft/lb torque if you remove them.
Old 08-16-2017, 10:14 PM
Question
$32.79
Thanks GLC, I am aware of this.
I was looking at those CENTRIC pads as well. That's good to know, that someone has used a product with great results.
I changed my front pads at 92K miles. I didn't turn the rotors because they were smoother than a baby's a**. I did a circular pattern on them with emery cloth. I will have to mic them to see if they need to be changed.
Anyone know the minimum thickness?
Old 08-16-2017, 11:05 PM
glc is offline
The only place that might be is cast into the rotor itself.
Now - if you do have to replace the rotors, Centric has a 2 piece conversion kit that uses the 4wd rotors.
CENTRIC 12165128 C-TEK Standard Disc
Front; RWD; 6 Lug; Hub & Rotor Assy; Upgrade Kit
$97.79
http://www.rockauto.com/en/catalog/f...hub,rotor,1896
The picture is wrong, this is a 2 piece upgrade kit according to Centric. I don't think it comes with a new spindle nut (NOT reusable):
http://www.rockauto.com/en/catalog/f...indle+nut,1616
Old 08-17-2017, 07:26 AM
Thumbs up
$97.79
GLC, you must be a mind reader, or have a web cam set up on my LT.
I was looking at that option as well. EBAY has 2 rotors, hubs, and ceramic pads for $133-$197. The spindle nut is $8.12. The rotors and the pads both have a lifetime warranty.
Old 08-30-2017, 10:38 AM
carioux2008's Avatar
I used raybestos EHT pads front and rear on my 08. Ive got to say they are probably the best pad ive ever used. they are definitely low dust and reasonably priced. I also used the raybestos professional rotors for the front (mine is a 2wd as well). I though about going with the centric bearing kit, but for the price i couldnt say no. i went over 70k on front rotors before they warped and needed replacement. i doubt ill have the truck that long again which is why i didnt upgrade to 4x4 front rotors and centric hubs.
Pads: http://www.rockauto.com/en/moreinfo....441659&jsn=589
rotors: http://www.rockauto.com/en/moreinfo....441659&jsn=689
The rotors came with a new spindle nut as well which was a huge bonus!
