who can back this up?
Will this really fit without level or lift?
Moto Metal MO970 - Machined Accents
Front: 18x9
Offset: +18
Backspacing: 5.7
Stance: Slightly Aggressive Rear: 18x9
Offset: +18
Backspacing: 5.7
Atturo Trail Blade MT
33"x12.5" 320/60
Suspension: Stock
Rubbing: No rubbing or scrubbing
Trimming: Minor Plastic Trimming
Front Wheel Spacers: None
Rear Wheel Spacers: None
I was looking for the max tire for a 20" rim to replace my stock tire. I dont have any lift or leveling since I just got the truck and I heard the warranty will be void if I level it or lift it.
They should fit at stock height. Ford can't just void your warranty unless they can prove the lift caused the failure of the part. In that case the only affected parts from the leveling lift would be ball joints, tie rod ends, struts, and c/v axles. The rest of the truck is still covered by warranty.
