Wheel tire clearance question 2010 4x4 Crew
What I have is a 2010 Crew Cab 4x4.
I purchased a wheel and tire combo with level kit and had it installed about 2 years ago.
Wheels are Fuel Throttle 20x9 with what I think I have measured as 5.5 backspacing. Tires are Amp MT 275-60-20.
This past weekend I hit the median with concrete curb at about 45mph and tore the sidewall up pretty good and knocked the alignment out or bent something in the front end.
Now time for a new set of tires which leads the question--how much bigger can I go with the wheels I have?
Looking for thoughts on something 34 inch tall less than 12 inch wide as Im sure that's about all I can get without rubbing.
The tires do not have to be MT but that's what Im used to so AT or MT would work. In FL its not that rough of terrain. The truck sits most of the time in the driveway and now has about 46000 miles.
https://www.toyotires.com/tire/patte...-terrain-tires
I wonder what it would take to trim and fit the Toyo RT 305-55-20 ?
I have to get it as close to correct before hand or its like inventing the wheel all over again.
