FUEL coupler wheels
FUEL coupler wheels
was looking to dump some money into my 2004 f150 fx4 and thought that new tires and wheels would do me good.
Came across the FUEL Coupler wheels. Black and Tinted would match the two-tone paint on the truck (Black with the gray accent down bottom).
The Couplers are 20x10 with (-12mm or -24mm) offset. I think the -12mm would put me at around 5" of backspacing. Thinking 33" tires (maybe Toyo MTs or the FUEL Offroad MTs).
Would this setup work on a stock FX4? How far out would these tires stick?
much appreciated.
much appreciated.
been looking for pics/video of what guys consider rubbing/trimming for similar setup but cant find anything. lock out to lock out while parked in the driveway is one thing but i wouldn't want to be driving, hit a big bump then have the tire catch something. also dont want to find this out after shelling out a few grand for wheels/tires.
thanks for the feedback.
yes, -24 will be way worse. I rub on the lower bumper trim piece and on the inside fender liner. So by pushing the wheel out more you may not rub on the fender liner, but it will make the rubbing worse on the lower bumper trim. I didnt trim anything. I choose to avoid tight parking lots and just park out in the middle of nowhere, so I never really have to turn hard in reverse.
on a side note, I dont have any sort of mud flaps, and the offset causes the tires to throw spary/mud/debris all down the side of my truck. I run a much higher offset wheel and narrower tire in the winter to avoid this, but if im driving in the rain with these wheels or on a muddy dirt road, the spray literally arcs up as high as the truck. so if you are trying to protect your paint job, have a winter set or get some mud flaps.
all in all im not trying to steer you clear of this set up. if i could go back i would do it the same way every time. just trying to make sure youre aware
