35s or 33s
I had an 02 FX4 as well. I'm pretty sure if you had just the stock wheels, you could fit the 35's quite stuffed under there. I think with the spacer pushing your wheel out more like an aftermarket wheel, 33's would be your best bet. Think you'd have some serious rubbing on the front valence and the back of your wheel well if you went with 35's.
35's are the way id go.. but id have to regear it too. You gotta have stock wheels for the 35's and its gonna rub the frame rails at full lock. 33's dont look bad.. less power loss its which look you like best and if you can live with the rubbing at full locks.
Here is my old one tbar cranked and aal.
but like said before, I'd avoid using the spacers.
