Need New tires?...don't know what to get
1 Attachment(s)
Hi all,
Just got my first truck, 2000 F150 Lariet.......I was planning on getting different tires for it, but after doing the coin test, I think it's a necessity. The center if the tires are down to just at 2/32, and the tread gets progressively deeper toward the edges, to a depth of 6/32 in the tread on the edge. This leads me to believe that new tires has become priority number one, does this sound right? If I need new tires, I'm kind of lost on what to get. I live in no ethers Minnesota, so snow and rain are always an issue. I do mostly pavedroad driving, bith there are a few places where I have to go on gravel, and offroad. I can only afford one set of tires at this time. Looking for some suggestions, can't really afford more than $150 a tire, sadly. Thanks Here's a picture of my front driver side tire.....all the tires are pretty much the same Attachment 12256 Edit: tire info added max pressure listed on the tires is 44psi max weight listed on the tires is 2535 pounds Tires are P265/70R17SL |
What pressure are you using on those tires? Center tread wearing more than the rest of the tire usually means over inflated. What is the tire size and load range? What is the max weight and max pressure shown on the side of the tire?
As you do travel on dirt and gravel roads, I suggest you get an LT tire, as they will stand up better than a P series tire. Unfortunately they usually are more expensive than a P series tire, but you can get some decent deals. As size and other info make a big difference in price, we will need that info. |
Running at 35 psi
max pressure listed on the tires is 44psi max weight listed on the tires is 2535 pounds Tires are P265/70R17SL I fiured there was an over inflation problem. got the truck 2 weeks ago and put maybe 300 miles on it. Tires were really underinflated when I got the truck....and the tire wear was pretty much what it is now...i figure it the tires were overinflated when it was being used, the went low sitting at the dealership |
Is this 2wd or 4wd?
Those tires look quite dry rotted. I would replace them before winter. A decent highway all season tire with a fairly aggressive tread is the BFG Rugged Terrain T/A. If you have a membership, you can get them at Sam's Club. |
Originally Posted by glc
(Post 5014320)
Is this 2wd or 4wd?
Originally Posted by Vaultdweller
(Post 5014315)
Running at 35 psi
max pressure listed on the tires is 44psi max weight listed on the tires is 2535 pounds Tires are P265/70R17SL I fiured there was an over inflation problem. got the truck 2 weeks ago and put maybe 300 miles on it. Tires were really underinflated when I got the truck....and the tire wear was pretty much what it is now...i figure it the tires were overinflated when it was being used, the went low sitting at the dealership See here for a list of tires that can be had in that size, although most will be well over the $150, at least as listed by Tire Rack. The Rugged Terrain is right at in a P series. The Firestone Destination LE 2 is a little lower in price and I have heard good things about them. The tires are also rated here by the customers. http://www.tirerack.com/tires/TireSe...65&PID=3196498 |
Originally Posted by kingfish51
(Post 5014330)
35 is correct for those tires or any P series with a max of 44. LT or XL P series (max 50) would be different. You should be able to find lots of tires in that size. Both P series and LT tires. A load range C LT tire will handle the dirt/gravel road better than a P series like you have, especially with the chance of flats/blowouts due to the harsh conditions. Keeping it under $150 will be the tough part.
See here for a list of tires that can be had in that size, although most will be well over the $150, at least as listed by Tire Rack. The Rugged Terrain is right at in a P series. The Firestone Destination LE 2 is a little lower in price and I have heard good things about them. The tires are also rated here by the customers. http://www.tirerack.com/tires/TireSe...65&PID=3196498 I was looking at the Cooper Discover ATP and Falken Rocky Mountain ATS, in my price range. There's a Discount tire about 70 miles from me. I don't have the tools or confidence to do my own tires, so I am kind of limited as to what I can get through retailers who install. Discount Tire and the Ford dealership are the 2 bigger retailers near to me. |
(Post 5014331)
Thanks for the link. I really wish I could go more than $150, but after the money down on the truck, I don't have much for liquid funds, and needing the tires before winter doesn't give much time to save
(Post 5014332)
Per the discount tire site, the Falken has a good rating. I would look at the Cooper Discoverer AT 3 too. This also has a good rating at Discount tire. Have also heard good things about them, although some have had trouble with balancing in the heavier (higher LR) tires. As you are in Minnesota, you will want something with a more aggressive tread for snow than a highway tire.
Wife found General Tire Grabber AT2 at a local place for $165-$185...she didnt have the tire size to know for sure....buy 3 get on free. Are those good tires, and is that a decent price?
I can only go by the reviews on tire rack and discount tire as I have no experience with General tires at all.. They seem to be a decent tire getting 8 - 9 out of 10.
Which tire was listed for that price? I assume the P series. General has that tire in a P series and a LR E tire. I doubt the LR E would be available that cheap. As far as price, that is more expensive than Discount or Tire Rack, but there you are not getting 4 for price of 3. |
I cannot speak authoritatively on those particular tire models, however I have been using Falken tires on various cars since the mid 90s, starting with a Toytoa Celica subjected to way too much abuse. Sadly Falken doesn't sell Mud tires, which are what I am going with down here in Texas.
You are leaving out some critical information for folks to help you for sure. Like size... There are a huge variety of sizes these trucks can be fitted with. What size do you need for your configuration? Not sure about your area, but you could check Walmat, Sams Club, Costco etc... to try to find a better deal on tires... |
Originally Posted by dbhost
(Post 5015100)
(Post 5014315)
(Post 5015100)
Goodyear Wrangler Duratracs
BFG A/T Toyo A/T II Extreme I like Cooper Discoverer M+S or Hankook iPikes for dedicated snowtires. But going to try the Duratracs this year |
| All times are GMT -4. The time now is 05:57 PM. |
