1998 won't start (ABS, BRAKE dash blinking) after replacing rear brake pads!
I changed (one side) of my 1998 Navigators rear brake pads today before it got dark, now it WON'T START! All it does is make a loud clacking noise, doesn't turn over, lights all over the place acting wacky (even the dome light), and the ABS & brake dash lights are blinking.
All I did was jack up the drivers side, take off the wheel, remove the pads from the caliper, removed the rotor (had to hammer on it) and cleaned it up, checked and cleaned up the parking brakes....then put it all back together w/ the new pads.
If I leave the key on I get all kind of noises from the dash & under the hood!
What went wrong!
What went wrong!
I have been messing with it in the dark, I disconnected the battery for 15min, didn't help.
In the on position the ABS & BRAKE lights blink once every 2 seconds (along with some other lights on all the time). When I go to start it, the red THEFT & the overdrive OFF light on the shifter start to blink.
Hooked up a scanner and got nothing.
I have never had any problems with this truck at all, until I changed those rear brake pads (drivers side only)??? There isn't a ABS sensor at the rear wheels on these are there....isn't it on the diff?
It's a fairly new battery, and I just used it to get the brake pads, ran fine.
But then when I charged the battery overnight (10amp) the battery didn't even get hot? Not even a little warm, ice cold....what does that mean?
Cranks like new now!
