F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Wheels, Tires & Brakes (https://www.f150online.com/forums/wheels-tires-brakes-29/)
-   -   Didn't know the 2011 F150 had autolearn for TPMS.. (https://www.f150online.com/forums/wheels-tires-brakes/462580-didnt-know-2011-f150-had-autolearn-tpms.html)
Damn Dirty Ape Dec 22, 2011 05:57 PM
apparently mine does. Tossed on a set of Monsters with new TPMS from ebay and no sensor light whatsoever. The light still comes on with the lamp test on the cluster but no errors. I thought they had to be associated, lest you live with the yellow light.
odd.
barneyz71 Dec 22, 2011 08:22 PM
odd.
Give it time... it will come on.
Damn Dirty Ape Dec 23, 2011 12:11 AM
37 miles so far.
DarrenWS6 Dec 23, 2011 08:50 AM
My light on my 07 didn't come on until 90 some miles.
Damn Dirty Ape Dec 23, 2011 10:46 AM
well I have a ford trigger tool so no big deal if it does .
kingfish51 Dec 23, 2011 11:23 AM
Let us know if that works as the procedure for resetting is totally different than earlier procedures. The new procedures does not include the reset tool.
Like the others state, it takes time. You will need to drive a steady driver above 25mph for at least 20 miles for it to go off (not the low pressure indicator, but sensor fault). That is if you used different sensors. If you used the same sensors, it may never go off as it does not care about sensor position (which spot on vehicle).
Damn Dirty Ape Dec 23, 2011 12:49 PM
I used different ones.
Damn Dirty Ape Jan 3, 2012 10:14 PM
75 miles since my last post and still no TPMS light other than self-check during startup.
Patman Jan 3, 2012 11:05 PM
The system changed when they went from band sensors to valve stem type, the light should have come on until the new sensors are learned
kingfish51 Jan 4, 2012 11:19 AM
I would be willing to bet that every night he parks within about 50' of the OE tires and wheels. A sensor fault will not occur immediately, it takes about 20 miles above 25mph to get the error. If he parks near the old tires and wheels, that would reset every night.
nunya53 Jan 7, 2012 09:31 AM
^^This
Damn Dirty Ape Jan 7, 2012 10:19 AM
No, I actually put the original wheels in the garage basement at my parent's house due to no room where I live about 4 miles away. When I do go there several times a week the wheels are probably 75-80 feet away. I've put about 200 miles on the truck now.
I have no idea myself why it hasn't come on. I'm going to go ahead and use the ford trigger device that the dealership gave me when I got the truck and make sure/go ahead and register them though.
kingfish51 Jan 7, 2012 11:25 AM
Have you gone any distance (over 20 miles without stopping) at one time? 200 miles in the time of this thread is nothing. My guess 4-5 mile trips. And that 75-80' m ay be close enough.
Damn Dirty Ape Jan 12, 2012 05:30 PM
I WAS right..
http://www.f150forum.com/f38/trainin...s-11-a-125055/
kingfish51 Jan 12, 2012 05:47 PM
Originally Posted by Damn Dirty Ape (Post 4756022)
When did you say you had gone through the reset process. You didn't. It does not autolearn anything. You have to go through the reset process as listed in the owners manual as was told to you.
