No brakes? Entire system brand new!
Truck is a 99 with rear drums. My problem is i cannot get the brakes to harden up. Replaced the entire system and still no brakes...Bled the heak out of it, no air in the lines, steady stream. I had to replace a line going from the master cylinder to the ABS unit, bled them again and no air came out, just fluid so im wondering where that air went or if i didnt bleed them enough. (gone through 3 quarts so far) The ABS light has been on for awhile tho. But breaks worked before i installed everything, just 1 caliper was seized up so i replaced both.
So far ive replaced the calipers, drum cylinders, master cylinder, brake booster, new hardware, rear brakelines aswell...so im outta ideas. Anything help would be appreciated!
Did you start the bleeding process at the farthest wheel from the brake fluid resevoir and work your way to the closest one last ?? i.e. passenger rear, driver rear, passenger front and drivers front, in that order. If you did, and you don,t have any fluid leaks then I would say you still have air in the lines. Let us know what you find once you get it solved.
I thought you go closest to the master cylinder? Thats the order i did it, but i can do it in reverse yet. I want to say its the abs unit. The book says it controls the brake line pressure, so it must have valves in it? Could they be stuck open? Here is the thing...They worked before i got new calipers, but not worth a damn. You hit the break, the petal goes half way down before it applies the brakes...Now i have nothing.
I started by putting on calipers, when i did that, i didnt have any breaks...Than i did the rear brakes. Backed the shoes out until they were light snug with the drum, bled the lines again, still nothing. Got the master cylinder last, pre bled it, and installed. Still nothing. No leaks that i can see either.
I had a similar problem with my 02. It started on my way home from work...went from very slight fade and then at the next light my foot went to the floor. At first they changed the master cylinder and a questionable brake hose but they couldn't get rid of the fade. (it should be noted at this point the mechanic said "I hope its not the abs unit") Half the time the pedal felt good, 45% of the time the pedal would fade and 5% of the time the pedal would just go to the floor. They bled the bejesus out of it and that didn't fix the problem either. So in an effort to save me the $616.85 the abs pump cost they replaced just about everything else...
Turned out to be the pump. The fluid was bleeding through it causing the fade. (or something, I'm not a mechanic... but I did stay at a holiday in express last night)
Good luck....
Good luck....
