WANDELL!! Will 35's fit?
I want to run 35x12.5x17's. I've got the AS 2.5" and the wheels in the signature. Will they fit? Will I have to trim anywhere?
Do you know the BS/OS on those wheels? Being they are a 9" wide wheel, depending on the other specs you might can do it, but will require some trimming on lower valence and maybe inner fender.
Wheel Specs
Bolt Pattern: 6 on 135 Diameter: 17.00 " Width: 9.00 " Style: Pro Comp Xtreme Alloy Series 6001 Finish: Chrome Construction: Aluminum Backspace: 4.75 " Max Load: 2200 lbs Hubcentric: Yes Offset: -6.00 mm |
if you are going to direct the post to a specific person just P.M. them....
No, they won't fit. TO use those wheels, you will need to add more lift or just go with a 33 inch tire. You would need an 8 inch wide wheel with 5.5 inches of BS to fit 35's.
Ok, thank you for the information WANDELL!!
| All times are GMT -4. The time now is 07:17 PM. |
