Confused about 33's
I put a 2" autospring leveling kit on my 2004 FX4 a few weeks ago. I have the stock Ford 20" rims and the stock Pirelli tires. I want to put 33's on my truck when I replace the tires.
Now, I want my tires to be wider, but I'm really wanting height. So, I naturally think upgrading from 275/55/20 to 285/65/20 or something like that. But I see several people here claiming that a 305/50 is also a 33. To me, this looks like a shorter, wider tire. I don't want my truck to be shorter. Inform me. Like I said, I want bigger tires on my stock 20's. I don't want any rubbing at all and I have a 2" Autospring leveling kit. Thanks! |
then you want a 305/55/20 its a 12x33.2-20
I'm assuming you have an FX4 4x4? You can fit a 285/65/20. You can also use this site to compare tire sizes.
http://www.miata.net/garage/tirecalc.html - NCSU |
Originally Posted by Fabrik8edDreamz
(Post 4458768)
Originally Posted by NCSU_05_FX4
(Post 4458853)
http://www.miata.net/garage/tirecalc.html - NCSU I do have an FX4. |
Originally Posted by OK04FX4
(Post 4459041)
Are you saying that a 305/55/20 is a taller tire? The tires I have now are 55's.
Here is the formula to figure out tire diameter: http://www.4lo.com/images/gearmetric-formula.gif The section width is the first number, the aspect ratio is the second number (will be a percentage), and the rim diameter is the third. The section width is also the width of the tire in millimeters. To get the width in inches divide the first number by 25.4. Hope this helps. |
Right, a 305/55-20 is basically a 33x12.50 while a 305/50-20 is essentially a 32x12.50.
UNC,
I not the brightest bulb so I always use the tire calculator but can you plug in a tire size in your equation as an example. |
For a 305/55/20:
(305 x 0.55 x 2) --------------------- + 20 = 33.2 This is the diameter. 25.4 305 ----- = 12 This is the width. 25.4 |
Originally Posted by wandell
(Post 4459116)
6 of one, half dozen of the other. The actual measurements will vary from tire brand to tire brand with a given size.
Go with a 295/60/20 from Nitto. I think this size is the best of both worlds. Fills the wheel well, yet narrow enough to not rub. I'm surprise more people don't go with this tire. If I had to do it again, I'd switch to these from my 305/55 tires.
Originally Posted by wasachevyguy
(Post 4469052)
(Post 4469130)
Why? Are you getting some rub? Or would you just rather have taller tires?
I put the 295/60/20 on my truck,and love them. They rub a little, but that could be from the offset on my wheels.
| All times are GMT -4. The time now is 05:25 PM. |
