35's on a level kit
Old Apr 1, 2010 | 12:38 AM
DiggyGambles's Avatar
35's on a level kit
Does anyone have pics of 35x12.50R20 with a level kit? can this be done without excessive rubbing?
Old Apr 1, 2010 | 12:40 AM
offroadn'98's Avatar
yes...forsure if you use stock 20's.
Old Apr 1, 2010 | 12:45 AM
So non-stock rims won't do it??
Old Apr 1, 2010 | 12:58 AM
depends the backspacing and the width of the riims
Old Apr 1, 2010 | 02:46 AM
noregrets's Avatar
I dont know what the backspacing on my rims are but i have that size on aftermarket 20"s and I dont have any rub besides when im fully cranked and going reverse over a big bump. So it works if you get the right rims...
Old Apr 1, 2010 | 03:09 AM
Just for a guideline, stock wheels are 20x7.5. w/5.5" of bs im pretty sure
Old Apr 1, 2010 | 09:20 AM
hawg_man's Avatar
Stock 20's are 8.5'' wide with 6.5'' backspacing. Using a stock rim and a really aggressive sidewall tire will usually cause some serious rubbing on the UCA. I know it was said in a thred up top that the Toyo MT's (35x12.50) will rub on stock rims because of the aggressive sidewall and the fact that they measure closer to 13'' wide.
noregrets - what are the specs on your rims, that could help others out in the future.
Old Apr 1, 2010 | 09:26 AM
Dog'em's Avatar
That is very true. If you go with an aftermarket rim 9" wide or under with a backspace close to 5.5 you may only have to do some minor trimming but they should work.
Old Apr 1, 2010 | 03:48 PM
Lightningquick's Avatar
i have 20s with average back spacing in a moto metal with 351220s and it only rubs in reverse and its as simple as cutting a tiny piece of the bottom air dam.just have not done it yet.
Old Apr 6, 2010 | 02:41 PM
Well my rims arrived.. 20x9 xd monsters.. +18mm.. gonna run 305/55/20 so Im hoping im good.
Old Apr 6, 2010 | 04:27 PM
Black FX420's Avatar
I just picked up my rims..... +30mm will a 305/50/22 rub? I have 2.5 AS installed
Old Apr 7, 2010 | 10:45 AM
jlstang351's Avatar
cant wait to see this combo!!
Old Apr 7, 2010 | 11:18 AM
ChrisAU's Avatar
You should be fine with that tire.
Old Apr 7, 2010 | 11:20 AM
ChrisAU's Avatar
Should be good to go...I too want to see pics!
Old Apr 8, 2010 | 05:23 PM
Damon@tirerack's Avatar
Former Sponsor
In my experience, as long as you have a 2" lift on the front, have more than +10mm offset on the wheels, and stay under 35" OD in tires you are usually OK. 0mm or lower offsets start getting tricky.
