Wide Stance
Old 10-15-2009, 01:54 AM
BlackedOutF150's Avatar
Wide Stance
Interested in purchasing some 20x10 wheels in the near future. Looking for a wide stance where the wheels stick out further than oem, and dont know much about backspacing and offset sizes. Any info/pics are appreciated.
Jeremiah
Old 10-15-2009, 11:00 AM
wandell's Avatar
How far the wheel sticks out is determined by wheel width and backspacing. The most common wheel spec for the 04-10's is a 9 inch wide wheel with 5 inches of BS, which results in a wheel that sticks out 2 inches farther than the OEM wheels. I wouldn't go with a 10 inch wide wheel. Most of them seem to have only 4.5 inches of BS which means they will stick out 3.5 inches farther than stock which is too far in my opinion.
Old 10-16-2009, 02:06 AM
Are there any cons/disadvantages of a 20x10 with 4.5 BS? Wandell, thanks for your response. I see that you have 16x10 rims on your truck, do they not stick out the same as a 20x10? Also, is a rim offset the same as the backspacing?
Old 10-16-2009, 08:10 AM
Neirti's Avatar
I did the same thing as you. I have 20x10s with 4.5" back spacing, with 6"
Heres kind of a picture i can get a better one if you like:
Neirti
Old 10-16-2009, 09:19 AM
gcart's Avatar
ill be watching this thread closely.
Old 10-16-2009, 12:07 PM
wandell's Avatar
The wide width and shallow BS can cause tire fitment problems and they also make the tires sitck way out on a 04-10 F-150. Personlly, I think a 9 inch wide wheel with 5 to 6 inches of BS is the best choice for an 04-10 F-150.
I do have 16x10's, but the 97-03 F-150's don't require as much BS as the 04-10's. The edge of my tire/wheel is just about even with the edge of my fender flares.
Old 10-16-2009, 12:43 PM
IDNC76's Avatar
this is what a 20x10 4.5"bs and 35/12.5R20 Toyo m/t's look like to give you an idea
they stick out alot, but it looks awesome
unless your lifted , i would stick with Wandell's recommendations find a 9" wide wheel with around 5" bs
Old 10-16-2009, 04:22 PM
IH8ATTN's Avatar
i have the 20x10 with the 4.5 BS and I love it. Yes the side of the truck gets dirty when muddin as I don't have flares (and don't really plan to) but it gives your truck a very aggressive stance.
its your call but atleast you now have a good idea what you are getting into
Old 10-16-2009, 04:43 PM
wandell's Avatar
Great pics. They really illistrate the point.
Old 10-17-2009, 12:47 AM
Awesome guys, i really appreciate the pics. Thats exactly what i am looking for. I plan on installing a 6" lift running 35x12.50 on 20x10 wheels with 4.5BS. Do i need to look for a specific offset or do all 20x10 rims with 4.5bs have the same offset? I am not well versed on offset and BS. Thanks again for the responses.
Old 10-17-2009, 10:41 AM
wandell's Avatar
Offset and BS are just two different ways of measuring the same thing. So yes, on all 10 inch wide wheels with 4.5 inche of BS, the offset will be the same.
Old 10-17-2009, 12:56 PM
IDNC76's Avatar
good point , i forgot to mention how many more times i had to wash my truck when i had the Mazzi's on
also, i had gotten a few fender flare warnings from the fuzz, just to keep that in mind
Old 10-17-2009, 01:33 PM
BLACKOUT FX4's Avatar
Mine are +18 offset and stick out almost 1" from the flares.
Old 10-17-2009, 02:29 PM
HMR's Avatar
HMR
HMR is offline
I'm interested in a set of 18 inch XD Monsters for my 06 fx4. I notice that they are available in three different offsets. -12 +18 and +35 in a 9 inch width.
I really don't want my tires to stick out much. Ideally, right to my fender line. I believe that the +35 measure would do that but my search hasn't revealed any one who has them.
Anyone? would I have any problem with the inside clearance?
thanks to anyone who can give me advice.
Old 10-17-2009, 02:59 PM
4.2trimble's Avatar
for what you are looking for i think the +18 would be best but id check with wandel
Quick Reply: Wide Stance
